Print at Sep 23, 2026, 4:37:09 PM
Posted by Puybaret at May 30, 2020, 9:13:11 PM
Re: Hidden HTML- tricks anyone?
There's another solution, which consists of enabling the preferences option Aerial view centered on selection then selecting the item that should be used as rotation center.
If you don't want to bother too much with JavaScript, copy these lines of codes just before the last </script> line of the HTML page:
setTimeout(function() {
homeComponent.getUserPreferences().
setAerialViewCenteredOnSelectionEnabled(true);
homeComponent.getHome().setSelectedItems(
[homeComponent.getHome().getFurniture() [0] ]);
}, 1000);
Here, this piece of code selects the first piece of furniture (represented by 0 between brackets []). If you want an other one, change the number between brackets [1] for the second one, [2] for the third one (not taking into account items in groups).
The last number 1000 represents the delay in milliseconds before this code is executed. Maybe it will have to last longer in your case.
