Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Levels, transparency and categories » » » » Post: Re: Levels, transparency and categories |
Print at Oct 4, 2026, 10:08:54 AM |
| Posted by Puybaret at Jun 6, 2020, 9:36:13 PM |
Re: Levels, transparency and categories Happy to see you back Pencilart If you want to search in the library, you should select the Searchable list option in the preferences. I'm not sure to understand what you mean by level transparency. At the moment, objects at lower levels are visible only if they are higher than the elevation of the upper level. If you added the staircase in level 1 before adding level 2, you could have drawn walls at the upper level around that staircase, couldn't you? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 4, 2026, 10:08:54 AM |
