Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Copy object to exact position? » » » » Post: Re: Copy object to exact position? |
Print at Oct 10, 2026, 12:01:03 PM |
| Posted by Mike53 at Jun 13, 2020, 4:08:52 PM |
Re: Copy object to exact position? when you copy/paste the new object will appear 200mm out on both the x and y axis, but, if you then delete that object and paste again it will appear in the correct position. alternatively you can create another level at the same elevation, you can in fact have as many as you wish, making different levels visible might be a better way to change textures or objects or group different textured objects and change the visibility of the group, the groups could be named to match a certain texture/colour, to enable ease of identification |
Current timezone is GMT Oct 10, 2026, 12:01:03 PM |
