Print at Sep 24, 2026, 10:43:51 AM
Posted by Mike53 at Jul 2, 2020, 1:00:32 PM
Re: Trapezoid Window
Whether you have made them yourself or downloaded them from elsewhere, during the import process you need to select (checkbox) that the object will be a door or window, once you have done that it should fit correctly into the wall and still enable you to modify the dimensions
