Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Why are the elevations wrong? » » » » Post: Re: Why are the elevations wrong? |
Print at Sep 24, 2026, 6:22:21 AM |
| Posted by ottertooth at Jul 3, 2020, 9:40:00 PM |
Re: Why are the elevations wrong? After I woke up this morning I thought about what UbuntuBirdy said about the levels again. It's true, I was on the wrong level. I have 3 levels in the basement because that's how the foundation was built. So I opened SweetHome after being away from it for a while, saw that I was in the basement, and went right back to drawing. But actually the level was set to 'North Basement'. I can still see everything in 'Basement' when it's set to 'North Basement'. There doesn't appear to be a way to see which level an object is on, in the 'Modify Furniture' dropdown menu. If there is, I don't see it. I do have 'Level' checked in Furniture > Display Column, so it should indicate levels there? But it doesn't. If I had seen it in Modify Furniture, I would have immediately realized I was on the wrong level. Now I see that the levels are shown in the lower left pane. Is there a way to switch objects to a different level? Or else I might have to delete everything I've done since returning to this project and do them over again. |
Current timezone is GMT Sep 24, 2026, 6:22:21 AM |
