Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Rendering speed is extremely slow comparing to a similar image. » » » » Post: Re: Rendering speed is extremely slow comparing to a similar image. |
Print at Sep 30, 2026, 7:51:22 AM |
| Posted by enkonyito at Jul 4, 2020, 10:09:01 PM |
Re: Rendering speed is extremely slow comparing to a similar image. I can't understand why when i'm rendering 2 different models with a generally speaking similar size and content (both models are of art galleries, both have ceiling and floor textures) One of them renders relatively fast Model A - 13m20s The other one is for some reason much much slower - Model B - 1h33m5s For both I am using the "Simple photo rendering 2.0" plugin with the same conditions and rendering settings: 1,500 x 1,000 px, Quality: 4, default lens, same time of day, no ceiling lights or sky lighting and SunFlow rendering engine (with exactly the same settings). Hi Elis, It would be interesting to have an example of model A rendering. Are the 2 models in the same file or in different files? Each file has its own saved rendering settings. Do you notice the same time difference with the standard Sweet Home 3D photo panel that uses the SunFlow rendering engine? To better understand your problem, if possible, you could make your project accessible to perform tests. Enko ---------------------------------------- EnkoNyito |
Current timezone is GMT Sep 30, 2026, 7:51:22 AM |
