Print at Sep 25, 2026, 6:51:38 PM
Posted by hansmex at Jul 5, 2020, 8:47:43 AM
Re: Putting skylights in a flat roof | Cutting holes in cubes | Merging walls across levels
1 - Import your window(s), rotate it to horizontal and mark it as a staircase during the importation process. If you insert it at the correct height, it will cut a hole in the floor/ceiling. Only works with square/rectangular windows.
1a - Alternatively, insert the windows in a wall, then export/import the wall and rotate it. This has the advantage that you can use any shape of window.
2 - You can't do this in SH3D, use other software. Remember: SH3D is 2D software that creates a 3D image.
2a - Alternatively, create your model from different parts and export/import it to use it as a homemade model.
3 - Draw your walls to the correct height. Create the levels needed as in the "first" process. Insert floors/ceilings on the levels where they are needed. If you need the walls to guide you during the creation of rooms, make your rooms on a differnt level, then copy them to the correct level.
