Print at Sep 24, 2026, 5:37:57 PM
Posted by Mike53 at Jul 13, 2020, 9:29:28 PM
Re: 3D model request: Pie shaped primitives
You should be able to create any shape of this type using walls and floors. Go to preferences set wall height and thickness to something like 3mm (1/8), draw a rectangle of walls approx the size of the tread needed. then modify each wall, length angle and arc to achieve the size and shape you need. Select the room tool and double click within your walls. Add another level to your plan, you can set its depth to match your tread. Copy/paste the room from the ground level to your added level. select the room and go to modify, uncheck the boxes for area and ceiling. Finally export it and import it
