Print at Sep 25, 2026, 9:26:43 PM
Posted by NemaTode at Jul 19, 2020, 10:07:39 PM
Starting with interior measurements and adding dimensions
Hi, I'm using SH3D for the first time and could use some help. All of my measurements are interior, and I'm trying to have all of the virtual walls accurate down to a 1/8". I'm running into problems adding dimensions when more than one dimension is starting at the same wall. I have keyed in the proper length of the wall, but I'm having problems lining up the walls so that the dimension measurement is the same as the wall length. How do I know when a wall is *exactly* lined up properly ? and with a dimension line?
Also, I didn't line up the "northwest" corner of the plan with the 0 coordinates on X and Y and now I really wish I had so that some of the wall measurements line up with the grid lines.
Thank you!
