Print at Sep 26, 2026, 11:39:37 PM
Posted by AeowynFraser at Jul 22, 2020, 10:29:54 PM
Re: 1928 Home Builders Catalog Co. house plans
So, I've made the adjustments (and a few additional yet minor changes).
I've added the trees to the front yard, raised the Attic windows about a foot, fixed the front steps, changed the wall texture from the White Roughcast with Stones to a similar colored stucco (except for the front and back steps and porches), shortened one of the front bushes so that I could add some of the lilies at the front corner, added the additional light and mailbox to the front porch, fixed the back wall, removed the little 'bump out' for the now unnecessary water heater, and made the side door not so shiny so that it no longer reflects the grass and background as much anymore.
I switched the rug texture to the dark wood texture on the stairs, and adjusted the size of the hanging lamp.
I changed some of the textures on the fireplace, fixed the textures on the coffee table so that it rendered better, and changed the texture on the round bowl holding the roses on the
And finally, I changed out the wall-mounted TV in the smaller back bedroom with a smaller one on top of the dresser.
I also realized that I'd forgotten to include the screenshots of each floor's floor plan, so here they are.
I figured that since I originally did the roofing strangely (no, I haven't fixed that) that there when I looked at it again that there would be (if I did adjust the roofing) a small crawlway between the large open area (that has the foldaway stairs) and the smaller area over the front 'chamber' so now that part is accessible... sort of I guess...
