Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Display 3d in a separate windows is blank » » » » Post: Re: Display 3d in a separate windows is blank |
Print at Oct 6, 2026, 9:46:35 AM |
| Posted by digitaltrails at Jul 28, 2020, 5:23:46 AM |
Re: Display 3d in a separate windows is blank Running 6.3 and 6.4, once I open in a separate window, it locks everything up. Would love to be able to use my other monitor, too. I wonder if this is the key. I retired from my coding days years ago and never did Java. I am willing to give this a try if someone can point me in the right direction. Thanks. If giving "this" a try means you would like to try editing the startup parameters, the process is the similar to the one described for increasing the memory allocated to Java. This is documented in the FAQ, see: How can I adjust the memory used by Sweet Home 3D? in: http://www.sweethome3d.com/faq.jsp Instead of modifying the text described in the FAQ, use a text editor to insert the following: com.eteks.sweethome3d.j3d.useOffScreen3DView=trueBackup the existing file before changing it. I can't be more specific because exactly what needs to be edited varies depending on your operating system. Note, you're not editing Java code, rather you're just altering scripts or config files (similar to mainframe JCL, UNIX shell scripts, or application property files). |
Current timezone is GMT Oct 6, 2026, 9:46:35 AM |
