Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: New Wishlist » » » » Post: Re: New Wishlist |
Print at Sep 29, 2026, 7:10:40 AM |
| Posted by harbinger at Jul 30, 2020, 6:37:04 AM |
Re: New Wishlist Addendum 7/30/20 Option to Continue walls at Same Height as Source Wall When continuing a wall from the endpoint of another wall, the user should have the option to draw the wall at the same height and perhaps with the other attributes (texture, shininess, etc) as the wall that holds the endpoint, instead of the default assigned in Preferences. This is especially useful when i'm using wall drawing as a means of creating shapes (before exporting to OBJ) -- the height of the wall may not be the default height (assigned in Preferences). Perhaps when a modifier key is pressed when starting to draw a wall from another wall's endpoint, the source wall's attributes are assigned to the new wall when the wall-drawing is stopped. Ignore Textures in Displays When viewing the floorplans esp. with the 3D window open, the more textures you have, the more it slows down the view as the camera moves. This is especially problematic when you're making fine edits to dimensions of objects but the display only updates once every half or whole second. I'd love to be able to toggle the view so the textures aren't drawn on any furniture or structural components, in both the 2D and 3D views. A keyboard shortcut would be the best way to quickly turn it off or on. Cornices Just like baseboards, i think cornices at the tops of walls where they meet the ceilings would be a nice feature for SH3D, and would eliminate a lot of guesswork and superfluous furniture. Of course, cornices should be measured from the top of a wall and should be independent of the ceiling structure. I'm especially needing this automatic addition in curved walls. At first, perhaps a simple triangle or block extrusion along the top of the wall should suffice, but accomodation should be made in the program's data structure so that future versions allow for custom-shaped cornices. |
Current timezone is GMT Sep 29, 2026, 7:10:40 AM |
