Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Important if you want to go back to an older version from v 6.4 » » » » Post: Re: Important if you want to go back to an older version from v 6.4 |
Print at Sep 29, 2026, 1:26:27 AM |
| Posted by Xiste at Jul 30, 2020, 9:34:13 PM |
Re: Important if you want to go back to an older version from v 6.4 I wonder if you didn't forget to update the max memory used in this new version. No, I gave it 32 GB just like with v 6.3.Most of my files are quite big, 1- 1.5 GB. When opening a 1 GB project, I can see an increase in memory usage of about 12 GB, a figure that is increasing every time I add some objects or make a rendering. When the the memory load reaches about 58 GB (on the 64 GB machines), the program is shutting down. I'm constantly monitoring my memory load, and I have made a routine of saving and quitting when the memory load is approaching 55 GB. It normally takes about 5 hours to reach 55 GB memory usage with v 6.3. With v 6.4, the 55 GB memory load can ( worst case) be reached within half an hour. Most of my computers are 12 core/ 24 threads MacPro 1.5, running OSX 10,13,6 (17G14019) They have 64 or 128 GB memory and NVIDIA GeForce GTX TITAN X 1228 MB. They can not be upgraded above OSX 10.13.6. Xiste |
Current timezone is GMT Sep 29, 2026, 1:26:27 AM |
