Print at Oct 5, 2026, 8:49:44 PM
Posted by Puybaret at Aug 23, 2020, 10:05:45 PM
Re: Problems with categories in BlendSwap-CC-0 furniture library
If the changes you made to the furniture library don’t appear, it could be because of the following reasons:
- you edited the SH3F file used by Sweet Home 3D and didn’t restart Sweet Home 3D after the modification
- you edited the SH3F file under another file name, that was read after the original file in Sweet Home 3D at import time or launch time. As the pieces of furniture in the libraries available for download have an id, the ones of your library with the same id will be ignored. In this case, you should remove the original library.
