Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Scaling issue for the background image, wrong aspect and size » » » » Post: Re: Scaling issue for the background image, wrong aspect and size |
Print at Oct 9, 2026, 12:39:40 PM |
| Posted by messefilme at Aug 27, 2020, 11:48:48 AM |
Re: Scaling issue for the background image, wrong aspect and size I just noticed that this problem occurs when you connect 2 or more walls. When I create a single wall it fits to the size of the background image. But if I create a second wall and combine them the value inside the distance field shrinks. For example: Wall without connection = 888 cm. Wall with connection to another wall, 90° shifted will reduce the value to 875,9 cm. I learned that I need to work with uncombined walls to have a correct value for the length of the wall. |
Current timezone is GMT Oct 9, 2026, 12:39:40 PM |
