Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Eclipse/Ant Build "Failed Build" » » » » Post: Re: Eclipse/Ant Build "Failed Build" |
Print at Sep 24, 2026, 6:20:10 PM |
| Posted by Puybaret at Jan 15, 2010, 10:37:26 PM |
Re: Eclipse/Ant Build "Failed Build" Don't be astonished if compilation fails: you must have added @SuppressWarnings("unchecked") annotation in SweetHome3DApplet.java and it's not supported in 1.2 source as reported in error message. Some times warnings are left on purpose... As written in SweetHome3DApplet javadoc: The bytecode of this class is Java 1.1 compatible to be able to notify users that it requires Java 5 when it's run under an old JVM. and again in build.xml: Compile Sweet Home 3D applets first with javac 1.1 to be able to detect current Java version during applet launch (otherwise Java 1.1 to 1.4 plug-ins refuse to load Applet class) ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 24, 2026, 6:20:10 PM |
