Print at Oct 6, 2026, 12:20:19 AM
Posted by ninja592 at Sep 5, 2020, 8:30:21 AM
Re: Problems with categories in BlendSwap-CC-0 furniture library
Thanks for your suggestions harbinger, I didn't think of checking for special characters.
When you mentioned you see the categories correctly, did you modify any of them?
Here's what I did:
- removed all furniture files
- with FurnitureLibraryEditor-1.25.jar, opened the original BlendSwap-CC-0.sh3f that I downloaded from the SH3D website
- deleted everything except for "Chicken"
- changed the category of "Chicken" from "Characters" to "Animals"
- saved the file under a different name
- imported the file
- the chicken was in the wrong category, it showed up in "Characters" when it should have been in "Animals"
- as test I removed it again and tried with another item: changed "Apple iPhone" from category "Miscellaneous" to "iPhone" and category "Electronics", but when I imported it, neither the name change nor category change was applied - so it doesn't seem that there are individual items that are corrupted (unless I was unlucky and picked exactly the 2 broken ones ;-)
I should probably mention as well that I'm using Windows & SH3D in English and I double-checked that I wasn't using any special characters for item & category names.
As a comparison, when I change the category of the animals in the BlendSwap-CC-BY.sh3f library, they work fine and all the animals are imported into the "Animals" category correctly.
Thanks!
