Print at Sep 29, 2026, 8:45:56 PM
Posted by AeowynFraser at Oct 11, 2020, 8:11:57 AM
Re: A home that I started about 10 months ago
This next design isn't one that I'd started last year, but I figured it worked here because of how I found it.
I was looking at Pinterest and this one house plan was suggested to me. When I followed its link it took me to Ebay of all places! Here are the pictures of that home.
It's a very small home, but not as small as a Tiny Home, and I wanted to see what it would look like set up the way that I would do so if it were my home. So I made a few changes/adjustments, and voila!! I've left the ceiling height at 10 feet, just as it is in the original, mainly because I like those extra tall windows that they created, and also because I thought that each room would seem claustrophobic if the ceiling height were at 8 feet.
As you can see, the only thing that I haven't included was the roof; I might add it in the future, but since I haven't changed the outside all that much from the original I figured that that's what the roof will look like and that's that. biggrin I actually liked the color of the siding that's on the original better than what I used.
I've made the Living Room my Sewing Room, with a little bit of "Living" still there with the fold-away couch (at least that's what it's supposed to be) for any possible overnight guest(s) that I might have.
I have the kitchen pretty much the same setup, but with the hot water heater tucked away inside that very skinny door near the back door. Also, I closed up the Study with a door; there's a good reason for that which'll be apparent shortly.
Here you can see the tiny hallway, with the wall mounted HVAC unit there, as well as the door to the Bedroom visible.
The Bedroom which I'm using here as storage for most of my sewing supplies and books.
The Walk-In Closet is basically the same except for the fact that I have the pocket door recessing to the left instead of the right as in the original; I thought that there wasn't really enough room in the wall for it that way.
The Bathroom pretty much the same as the original, except I think that I have the window smaller.
The "Study" which I've decorated as my bedroom. I was able to add a bed, although it is actually smaller than a standard Twin size - I've seen it called a Youth, Junior, or Truck Mattress: 33-inch by 66-inch if I remember correctly.
Screenshot of the floor plan. I don't think that there's much room for an attic space though, so I didn't include one.
