Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Rotation different between box and triangle » » » » Post: Rotation different between box and triangle |
Print at Oct 13, 2026, 3:47:39 PM |
| Posted by bert.struik at Oct 19, 2020, 7:34:07 PM |
Rotation different between box and triangle Why do boxes and triangles rotated about the X axis act differently? When a box is shaped as a board with 1" width, 6" height and 48" depth, it's depth is along the Y axis. It will rotate about the X axis as expected. The dimensions make a board that would be flat against a vertical wall that is along the Y axis. When a triangle is shaped as a board with 6" width, 6" height and 1" depth, it's width is in the Y axis. It will rotate about the Y axis when a value is inserted in the X axis of the modify furniture menu. The dimensions make a triangle that would be flat against a vertical wall that is along the Y axis. |
Current timezone is GMT Oct 13, 2026, 3:47:39 PM |
