Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Rotation different between box and triangle » » » » Post: Re: Rotation different between box and triangle |
Print at Oct 2, 2026, 11:14:59 PM |
| Posted by Puybaret at Oct 22, 2020, 11:05:05 AM |
Re: Rotation different between box and triangle As you noticed, the axes of the horizontal rotation of the objects depends on how you already rotated around its vertical axis: their X rotation axis is parallel to the thick line drawn in front of the object in the plan, and their Y rotation axis is perpendicular to this thick line. The little arrow used to handle the rotation around a horizontal axis is also supposed to help you guess this axis. Object rotated around its X rotation axis: Object rotated around its Y rotation axis: ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 2, 2026, 11:14:59 PM |
