Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Crashing on close, MacOS Catalina » » » » Post: Re: Crashing on close, MacOS Catalina |
Print at Oct 2, 2026, 2:24:33 PM |
| Posted by Puybaret at Oct 28, 2020, 1:30:47 PM |
Re: Crashing on close, MacOS Catalina About your first issue, would you use two screens? If it's the case, doesn't the program behave better if you close the 3D view window after moving it on the same screen as Sweet Home 3D main window? Otherwise, you could attach the 3D view to the main window by removing the line <property name='com.eteks.sweethome3d.swing.HomeComponent3D.detachedView' value='true'/>About the second issue, go the folder Library/Containers/com.eteks.sweethome3d.SweetHome3D/Data/Library/Application Support/eTeks/Sweet Home 3D/recovery of your user folder and remove the files you'll find there. An easy way to reach that folder is too choose the Go > Go To Folder menu item in the Finder and copy-paste ~/Library/Containers/com.eteks.sweethome3d.SweetHome3D/Data/Library/Application Support/eTeks/Sweet Home 3D/recovery (with the leading tilde) in the prompted dialog box. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 2, 2026, 2:24:33 PM |
