Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Need help » » » » Post: Re: Need help |
Print at Oct 4, 2026, 9:26:42 PM |
| Posted by hansmex at Dec 5, 2020, 2:09:44 PM |
Re: Need help STEP BY STEP EXAMPLE - Draw a room of 8x8 meters - In the middle of the room draw a wall 180 cms long - Modify walls > Arc Extent > 180 degrees - This gives a semi-circular wall - Draw a second wall from exactly the same X,Y coordinates - Modify walls > Arc Extent > 180 degrees - This gives a prefect circle in the middle of the room - Draw a wall from one corner to the diagonally opposing corner, this bisects room and the circle - Give walls a thickness of 0.1 cm - Insert two rooms - You now have two rooms with a semi-circular opening - Delete interior walls used for construction - You are left with a perfect hole in the floor (and a narrow diagonal slit). example file H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Oct 4, 2026, 9:26:42 PM |
