Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Can someone please explain plan view "other level' wall visibility? » » » » Post: Re: Can someone please explain plan view "other level' wall visibility? |
Print at Oct 3, 2026, 9:10:27 PM |
| Posted by dorin at Dec 19, 2020, 10:07:13 AM |
Re: Can someone please explain plan view "other level' wall visibility? I have never seen this? I see it and I think is the correct mod.Can someone please explain them? I'm not an expert but I try.In SH3D are two category of objects: plan components and furniture. They all belong to a level. From plan component only walls (if have enough high) will appear on upper level. The rest only on selected level. Usually I make multilevel plans especially because is this feature. Way I use multiple levels? Sometime at same elevation (for pipes, wires, dimensions, some labels etc.) and I need to see ONLY one at a time. Sometime at a little high elevation (5~10 cm) for floor to hide some pipes or heating system and again at same elevation but an other level for some furniture. All levels could be made visible in 3D for a better view. Unfortunately I'm not a native Java speaker Me neither!it's taking me more than a few moments to grok it I try this for two years and I can't get anything, but I steel insist. Just curious if I should just patch this for myself Of course You can try but first You have to learn how to do this.Then maybe teach me how to do. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Oct 3, 2026, 9:10:27 PM |
