Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: SH3D refuses to save my file » » » » Post: Re: SH3D refuses to save my file |
Print at Sep 24, 2026, 9:37:13 PM |
| Posted by Puybaret at Feb 2, 2010, 1:05:03 PM |
Re: SH3D refuses to save my file I was able to recover a part of your file and send it to you I was obliged to delete the following furniture : vase, shower, 滚筒洗衣机, 带柜洗脸盆 and remove textures on floors and walls. Knowing that a SH3D file is a ZIP file and that the Jar command of the JDK is very tolerant, here's an other tip for advanced users that might help to recover most items in a wrong file: - If you're under Windows or Linux, install JDK available at http://java.sun.com/javase/downloads/ (JDK is preinstalled under Mac OS X). - Create a temporary directory anywhere (I'll name it /path/to/tmp). - Open a Terminal or Command window. - Go to the temporary directory you created with cd command. - Type the following command to unzip most of your corrupted SH3D file: jar xf /path/to/corruptedFile.sh3d- Type the following command to zip Home entry and other unzipped files from temporary directory in a new file name fixedFile.sh3d: jar cfM /path/to/fixedFile.sh3d Home *- Try to open fixedFile.sh3d, remove or replace furniture with a red box, and reset the texture of walls and rooms that appear in red. I hope this will help. [Note from developer: The version 4.4 introduced a new system based on the previous method and able to automatically repair SH3D files] ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 24, 2026, 9:37:13 PM |
