Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Door Frames » » » » Post: Re: Door Frames |
Print at Sep 27, 2026, 5:10:23 PM |
| Posted by hansmex at Jan 12, 2021, 10:31:46 PM |
Re: Door Frames The two images show door frames that will not work, because the underside is open. Once you insert them in a wall, the wall will fill the frame. You need a connection between the two "feet" to close the frames. Make the connection as narrow as you like. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 27, 2026, 5:10:23 PM |
