Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: SH3D refuses to save my file » » » » Post: Re: SH3D refuses to save my file |
Print at Sep 24, 2026, 1:29:33 PM |
| Posted by Puybaret at Feb 3, 2010, 1:19:47 PM |
Re: SH3D refuses to save my file To avoid problems with renaming or moving files, all imported models and opened files are copied into temporary files or application directory. So if you experience some problems when saving a SH3D file, I consider it as a bug and it should be fixed, except if you use some temporary files cleaner or you played with files in application directory. - Under Windows, application directory is C:\Documents and Settings\user\Application Data\eTeks\Sweet Home 3D. - Under Mac OS X, it's the subfolder Library/Application Support/eTeks/Sweet Home 3D of your user folder. - Under Linux and other Unix, it's the subdirectory .eteks/sweethome3d of your user directory. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 24, 2026, 1:29:33 PM |
