Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to Render with Flat Colors, like a Material ID? » » » » Post: Re: How to Render with Flat Colors, like a Material ID? |
Print at Aug 27, 2026, 2:41:40 PM |
| Posted by HdFeX47 at Jan 23, 2021, 7:16:12 PM |
Re: How to Render with Flat Colors, like a Material ID?You could try this: - select all in your home - export the selection to OBJ format - edit the MTL file where you'll change the number following illum by 0 to get lines illum 0 - import the exported OBJ file as a piece of furniture in a new Sweet Home 3D project - go to the point of view you want and create a photo Thank you. I also had to also change the materials to just flat colors to make it exactly like the image, if any one tries to do the same. Also, to not lose your project by changing all the materials, just save as a new one and do those steps. After that, the masks works like a charm. |
Current timezone is GMT Aug 27, 2026, 2:41:40 PM |
