Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Basement Level (Hole In Ground) » » » » Post: Basement Level (Hole In Ground) |
Print at Oct 6, 2026, 6:11:41 AM |
| Posted by snmavronis at Jan 27, 2021, 7:58:49 PM |
Basement Level (Hole In Ground) If you had your main floor ( level 1) at elevation 0 modeling your real home but in fact in reality it’s several feet above outside ground level, how do you change that so the basement (level 0) is partially above ground level? I’ve already created my entire first floor with furnishings and everything, being new to SH3D. Can I reset the first floor elevation without screwing the vertical location of every object? Actually I’d like to create the exterior too and my front and backyards which slope away from my house. I didn’t realize a basement would carve a hole in the ground. I wish the house was floating in virtual space and then I could create the landscape without a false ground effect, I.e., basement level hole. ---------------------------------------- Steve N Mavronis - Retired PC Tech |
Current timezone is GMT Oct 6, 2026, 6:11:41 AM |
