Print at Sep 29, 2026, 4:14:46 AM
Posted by hansmex at Feb 5, 2010, 3:50:06 PM
Re: Problem to create a photo
Horst:
You could make a VERY simple design with just 1 or 2 standard items and try if it works OK. If so, the programs runs fine. You could also try a design you made a few weeks ago and see if it still works OK.
If you can make a succesfull rendering of a very simple design, than you may inspect the design with the problems. Maybe one of the objects you used causes the problems. By deleting one object at a time you can find out which object it is.
Alternatively check the forum section that deals with 3D problems. Sometimes graphics cards or drivers may cause problems.
