Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Not able to get precise wall dimensions » » » » Post: Re: Not able to get precise wall dimensions |
Print at Sep 25, 2026, 2:04:56 PM |
| Posted by snmavronis at Jan 29, 2021, 5:59:53 PM |
Re: Not able to get precise wall dimensions I just make a rough room shape or wall first. Then I drag the corners and on screen it shows you the inner wall dimensions as you do this. If you zoom in enough it can be as precise as 1/8” accuracy. I’m not sure what the metric system precision is if you use that. The drag precision works with room floor shapes and dimensions too. I never use the wall modify properties except to alter the wall thickness or height that I need. I don’t use that to set a length. ---------------------------------------- Steve N Mavronis - Retired PC Tech |
Current timezone is GMT Sep 25, 2026, 2:04:56 PM |
