Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Extensive memory usage? » » » » Post: Re: Extensive memory usage? |
Print at Sep 24, 2026, 7:54:21 AM |
| Posted by Puybaret at Feb 8, 2021, 11:36:43 AM |
Re: Extensive memory usage? I would suspect that it's because of the way Java handles memory with its garbage collector. The more memory you grant to the program, the more it will use and the less it will spend time in recovering allocated memory that is not needed anymore. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 24, 2026, 7:54:21 AM |
