Print at Oct 3, 2026, 11:02:53 PM
Posted by snmavronis at Feb 13, 2021, 2:08:05 AM
Stairway Holes
I was experimenting tonight with making holes between floors to accommodate custom stairways as regular (non-stair) objects. I can modify the room shape to open a stairwell hole but then the upper level's ceiling of course is also open. I can import a box shape as stairs and make invisible. But you have to over extend past walls or else the floor texture is between the upper floor and lower ceiling. With the invisible box past the inner wall I can add a faux "box" wall to cover it up. The bad thing is the upper floorplan doesn't show the stairs opening. The cleanest approach would be to modify the room shape and add a faux ceiling box so you don't see the sky. I know these 2 methods are unconventional. Any ideas or workarounds? Just using a custom staircase with 90 degree turns at each end and imported as stairs has it's own problems in my case, since the top part of the stairs angled turn overlaps a kitchen wall and bottom as a 90 degree landing riser onto the living room.
Steve N Mavronis - Retired PC Tech
