Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Feature: Show/hide dimensions » » » » Post: Re: Feature: Show/hide dimensions |
Print at Sep 27, 2026, 8:12:23 PM |
| Posted by hansmex at Feb 9, 2010, 7:31:11 PM |
Re: Feature: Show/hide dimensions Mr. Rostov: It's logical that if you add many dimensions using Plan --> Create dimensions your screen will look very full and cluttered. There is a different way to get a lot of information about an object. If you look at the bottom-left part of the screen you will see a list of all objects used. Right-click there and a pop-up menu opens. Now choose Display column and you will see a list of fields that you can display in this window. Select the items you want to see and those columns will be visible ![]() Back to the project you are designing. Select an object that you have inserted. Now look at the list at the bottom-left: your object will be highlighted and you can easily see all the data of the object that you have selected. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 27, 2026, 8:12:23 PM |
