Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Item to Level Assignment » » » » Post: Re: Item to Level Assignment |
Print at Sep 30, 2026, 3:40:26 AM |
| Posted by Mike53 at Feb 21, 2021, 6:02:39 PM |
Re: Item to Level Assignment Similarly, negative values have been mentioned in the past, position the item on the correct level but apply a negative elevation, this would ensure the object would only be viewed when that level is selected, if at any time you wanted/needed to view all, then you could select that option in the "3D view menu". If you are finding it gets in the way of your view, you could, for now, position a smaller triangle on level 0. and a larger one, combined with a box, on level 1. The box or exported wall that you have used as the back of the laundry cupboard could have been be placed on level 1 anyway. A "slicing tool" however could have other uses too. Some good renders have been shown where walls etc have been lowered or made opaque, imagine just slicing a section away. |
Current timezone is GMT Sep 30, 2026, 3:40:26 AM |
