Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: fill space in between internal/external walls » » » » Post: Re: fill space in between internal/external walls |
Print at Oct 3, 2026, 9:42:13 PM |
| Posted by Mike53 at Feb 22, 2021, 10:22:49 PM |
Re: fill space in between internal/external walls You could try this Create a level 5mm below the height of your wall with the floor thickness set to 5mm draw walls to fill in the gaps create a texture, something like "Paint" draw black diagonal lines on it import the texture and use it as the floor texture remember to un-check the box's for area and ceilings when modifying the room. Here is a very quick attempt ![]() |
Current timezone is GMT Oct 3, 2026, 9:42:13 PM |
