Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Error with run configuration on Mac 10.15 » » » » Post: Re: Error with run configuration on Mac 10.15 |
Print at Sep 24, 2026, 12:06:24 AM |
| Posted by treehousenorris2 at Feb 26, 2021, 4:18:51 PM |
Re: Error with run configuration on Mac 10.15 Aha, the Exception turns into just a Warning in an older Java 8 build, per the tip here. 2021-02-26 11:16:54.697 java[39444:560969] WARNING: NSWindow drag regions should only be invalidated on the Main Thread! This will throw an exception in the future. Called from ( 0 AppKit 0x00007fff2ec02629 -[NSWindow(NSWindow_Theme) _postWindowNeedsToResetDragMarginsUnlessPostingDisabled] + 371 1 AppKit 0x00007fff2ebea052 -[NSWindow _initContent:styleMask:backing:defer:contentView:] + 1416 2 AppKit 0x00007fff2ebe9ac3 -[NSWindow initWithContentRect:styleMask:backing:defer:] + 42 3 libnativewindow_macosx.jnilib 0x00000001270f93fe Java_jogamp_nativewindow_macosx_OSXUtil_CreateNSWindow0 + 398 4 ??? 0x0000000112b13667 0x0 + 4608570983 ) 1.8.0_271 Oracle gives the error 1.8.0_265 AdoptOpenJDK gives the error (1.8.0_252+ the problem first started appearing) (1.8.0_242 no longer see the issue) 1.8.0_241 Oracle gives the warning yet successfully runs, yay! |
Current timezone is GMT Sep 24, 2026, 12:06:24 AM |
