Print at Aug 9, 2026, 5:09:27 PM
Posted by digitaltrails at Mar 3, 2021, 7:05:06 AM
Re: Sweet Home 3D 6.5
Sweet Home 3D 6.5 was released tonight. Many thanks for your help and feedback.
Would it be possible to detect the useOffScreen3DView situation and automatically correct it?
Unfortunately no, since offscreen 3D support can't be detected reliably under Linux.
Thanks for making this new release and also thank you for the prompt response to my question.
I haven't looked at the code, but if on Linux
awtComponent com.eteks.sweethome3d.j3d.Component3DManager throws and exception at startup, could the SweetHome3D error/exit-dialog offer an option such as "Should SweetHome3d attempt a restart with the alternative useOffScreen3DView setting?".
If that's too complicated, would it be possible to add a suggestion or help-link to the exit-dialog.
I guess the Linux tar could ship with a third startup script like SweetHome3D-Java3D-1_5_2, but called SweetHome3D-useOffScreen3DView. Or maybe even a README in the install folder.
All in all, not a big issue, but addressing this issue might prevent some repeated forum posting here and elsewhere.
