Print at Oct 6, 2026, 2:59:49 AM
Posted by snmavronis at Mar 9, 2021, 12:34:01 AM
Levels Elevation Change
In the Modify Level dialog box if I change the 3 level's elevations so that the basement is 0' elevation and adjusted the other 2 levels relative to that, do each item's elevations within each level adjust accordingly so everything looks the same as before? I want to raise the entire house so I can make the proper landscape outside that slopes away from the house, because ground level is several feet below the main level elevation.
Steve N Mavronis - Retired PC Tech
