Print at Aug 9, 2026, 11:16:50 AM
Posted by calawide at Mar 12, 2021, 11:19:17 AM
Re: Import *obj - files created MS 3DBuilder not possible
Ciao guys I got same problem. I use "Autodesk Tinkercad" (tinkrcad.com) to create some objects then I export them as OBJ+MTL. No way to import this file in SH3D. I found a workaround (very complicated). sometimes working sometimes not. I import the OBJ in "3D Builder", free Microsoft App, I rotate the object as needed then I export it again to OBJ format, now it is possible to import the object as a forniture. The problem is that not lways work. HELP!!!
