Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Terrain Generator plug-in » » » » Post: Re: Terrain Generator plug-in |
Print at Sep 23, 2026, 10:37:31 AM |
| Posted by Puybaret at Mar 29, 2021, 3:11:23 PM |
Re: Terrain Generator plug-in Any hole you'll draw in your room(s) will appear in the plug-in dialog box too. For example, if you want to draw a two level house on a slope like the one attached to this post, you could draw a room that surrounds the garage like the green room in the following image. ![]() If you don't know how to draw a room with a hole, look at this video or draw two rooms which won't include the house surface. Then, if you select this room and the path to the garage to build a terrain from them with the plug-in, you can design a slope which will show the hole of the garage. ![]() After a few tries, you'll get the following nice little house that you may visit in 3D here. ![]() ---------------------------------------- ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 23, 2026, 10:37:31 AM |
