Print at Sep 23, 2026, 10:37:33 AM
Posted by Puybaret at Apr 29, 2021, 4:07:03 PM
Re: Terrain Generator plug-in
Here's the version 1.1 of the Terrain Generator plug-in which provides some small bug fixes and the following improvements:
- A wireframe view of walls, rooms and furniture visible in the 3D view will now be displayed in the preview of the plug-in dialog box, unless you unselect the new Display home wireframe check box. This should be helpful when you need to adjust the elevation of some points according to the elevation of some windows or upper floors.
- The new Influence radius field will let you enter the value of the maximum radius of the disk centered on the elevated point where other points will be elevated too, or when alignment is activated, the half value of the maximum width of the band around the elevated point.
- Some feedback was added to show the elevated point and the influence disk or band where points will be elevated while dragging the mouse, as shown in the following videos.
Hope you'll like these new features smile
