Print at Sep 24, 2026, 12:31:33 PM
Posted by hansmex at Feb 19, 2010, 6:27:22 PM
Re: inserting a window breaks custom texture
Richard:
What happens is this: every time you insert an object in a wall, SH3D (internally) begins a new wall segment. That means that it also re-starts the texture. It is this effect that you have noticed.
If it is important that the texture is seamless, you can make a tailor-made texture for that wall. See this manual .
Another solution would be to insert the window at the exact start of a new texture. Maybe using a close-up view of the textured wall will allow you to place the window (or door) on the exact right place.
