Print at Oct 12, 2026, 10:53:53 AM
Posted by madduck at May 18, 2021, 6:53:52 AM
Adding lintols (lintels) between two walls
I am trying to add a lintel/lintol to a wall that's been removed, i.e. there is now a structural beam at the top (height 50cm, elevation 200cm), which is considered part of and integrates perfectly with the wall.
I cannot create a wall that has an elevation. This post this post suggests I add another level and change its elevation to 200cm, then add a wall of 50cm, but this seems like a pretty bad hack.
Similarly, using a "miscellaneous box", as suggested here, but that is also a hack, and the box is displayed in a different shade than the wall (despite the colours being exactly the same).
An alternative might be a "frameless door frame", but no such object seems to exist.
How is one supposed to do this properly?
