Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Export OBJ without floor » » » » Post: Re: Export OBJ without floor |
Print at Sep 28, 2026, 3:52:31 PM |
| Posted by Puybaret at Feb 23, 2010, 10:05:48 AM |
Re: Export OBJ without floor Don't remove the line starting with "g wall", remove only the ones starting with a "f" and preceding that line. A f-line defines a face and the number of f-lines to delete depends on the shape of the rooms you created. The simplest ground is a rectangle made of two triangles i.e. only two f-lines. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 28, 2026, 3:52:31 PM |
