Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Export OBJ without floor » » » » Post: Re: Export OBJ without floor |
Print at Sep 29, 2026, 8:29:31 AM |
| Posted by hansmex at Feb 23, 2010, 11:53:13 AM |
Re: Export OBJ without floor Emmanuel: Let us assume that I delete ALL the f-lines from the OBJ-file. That means I would create an object that has no "bottom" faces, and therefore also doesn't have the unwanted "extra" floor. The price is that I also lose those floors that I DO want to have. If I were to create an in-between layer that consists only of the textured floors, then again I have the problem of the extra floor that follows the extreme points in the design. The only advantage would then be, that there are less floors, and it might be easier to find out which floor is the unwanted one. I shall keep this in mind, and maybe experiment a bit. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 29, 2026, 8:29:31 AM |
