Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Export OBJ without floor » » » » Post: Re: Export OBJ without floor |
Print at Sep 29, 2026, 5:35:20 PM |
| Posted by Puybaret at Feb 23, 2010, 1:16:10 PM |
Re: Export OBJ without floor I you remove all the f-lines from an OBJ file, you create an empty model! "f" means face not floor. If you removed the f-lines I indicated to you, you won't remove the floor of the rooms you created with Create rooms tool. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 29, 2026, 5:35:20 PM |
