Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Export OBJ without floor » » » » Post: Re: Export OBJ without floor |
Print at Sep 28, 2026, 10:45:32 AM |
| Posted by hansmex at Feb 23, 2010, 2:43:42 PM |
Re: Export OBJ without floor Emmanuel: I'm afraid I can't follow your explanation :-( When I open a file, I find many-many lines that start with "g wall_xx_xx" where xx_xx are numbers. In that particular file the first "g wall" is preceded by 44 lines that start with "f". I assume those are the faces of the walls I have drawn at the start of the project. All the other occurences of "g wall" are preceded by only 2 lines that start with "f". So, how can I determine which f-lines to delete? Should there be one (and one only) wall that starts with "g wall" and has no numbers following? I don't have the patience to use the trial-and-error method and delete each (pair of) f-line(s) to find out which line is the unwanted floor. Sorry for that. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 28, 2026, 10:45:32 AM |
