Print at Aug 9, 2026, 11:34:17 AM
Posted by Puybaret at Jun 18, 2021, 11:57:17 AM
Re: Sweet Home 3D JS Online
Finally, the error under Windows can be fixed easily: in build.xml Ant file, just replace colons (:) in the two following lines
<arg value="../SweetHome3D/src:tools/JSweet/src" />
<arg value="def:com/eteks/sweethome3d/model:com/eteks/sweethome3d/tools:com/eteks/sweethome3d/viewcontroller:com/eteks/sweethome3d/io" />
by ${path.separator} (see fix here).
By the way, if you want to generate SweetHome3DJS.war file, don't forget to run Ant default target in SweetHome3D project too. SweetHome3D.jar is required to generate the war file.
