Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: High quality rendering problems since PhotoVideoRendering plugin 2.2a » » » » Post: Re: High quality rendering problems since PhotoVideoRendering plugin 2.2a |
Print at Oct 5, 2026, 5:05:21 PM |
| Posted by mgincnj at Jul 7, 2021, 4:28:18 PM |
Re: High quality rendering problems since PhotoVideoRendering plugin 2.2a Thanks for weighing in. Much appreciated! I did edit the SweetHome.cfg file and increased memory from 2000 to 4000m. The FAQ suggested I might need to run a Terminal command to get MacOS to permit me to edit the file, but my experience was it allowed me to save the changes without a challenge, so I didn't go into Terminal. In any event, the standard Create Photo option still generates a plain gray image. I then re-installed the YafaRay plugin and it does the same thing (though generating the gray image in a circular fashion rather than rectangular). What's odd is that there seems to be some sort of persistent memory leak that cuts across all of the high quality renderers. For a while the SunFlow renderer was not working in the plug-in, but was in the Create Photo dialog. Then it started to get flaky, and now generates only a plain gray image as well. Is there a way to perform a clean reinstall of 3D Home while preserving points of view and libraries? I've got a lot of work invested in creating texture and furniture libraries, as well as creating stored points of view... I would hate to lose that work. But for weeks the program has worked reliably. YafaRay rendering was always flaky, but SunFlow worked ok. |
Current timezone is GMT Oct 5, 2026, 5:05:21 PM |
