Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D JS Online » » » » Post: Re: Sweet Home 3D JS Online |
Print at Aug 9, 2026, 11:37:48 AM |
| Posted by Puybaret at Jul 12, 2021, 3:21:30 PM |
Re: Sweet Home 3D JS Online I'm pretty sure you're not using JDK 8 to build the project. I just tried with JDK 15 and got the same error. If you use Terminal, set JAVA_HOME environment variable to ensure Ant uses the right JDK. Do I have to put the sweethome3d.jar in any specific folder to aid the building? No, just leave it in its default place, but SweetHome3D and SweetHom3DJS projects must be in the same folder.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 9, 2026, 11:37:48 AM |
